D dubb Young grasshopper Feb 26, 2019 70 9 Usa Mar 5, 2019 #1 I like the form factor of that camera but I plan on using blue iris. I know I can use it with blue iris though. It will be in my office mounted at the ceiling. I also need to record video and audio.
fenderman Staff member Mar 9, 2014 36,891 21,408 Mar 6, 2019 #2 dubb said: I like the form factor of that camera but I plan on using blue iris. I know I can use it with blue iris though. It will be in my office mounted at the ceiling. I also need to record video and audio. Click to expand... What is it about that design that you want?
D dubb Young grasshopper Feb 26, 2019 70 9 Usa Mar 6, 2019 #3 fenderman said: What is it about that design that you want? Click to expand... It is small, and can blend in on the white background. I did actually buy it but I’m looking for reasons to return it. The mounting also seems very simple.
fenderman Staff member Mar 9, 2014 36,891 21,408 Mar 6, 2019 #4 dubb said: It is small, and can blend in on the white background. I did actually buy it but I’m looking for reasons to return it. The mounting also seems very simple. Click to expand... Its about the same size as a fixed turret camera.
C curmudgeon n3wb Oct 23, 2017 19 15 Mar 7, 2019 #5 Doesn't it have the new firmware that enables RTSP, allowing you to just use it with Blue Iris?
