Is there a better IP Config or Toolbox?
Jan 1, 2024
821
405
USA
So looking for a better tool then the ones I am using. Is there anything better then then Dahua Config Tool or one like the Alibi Toolbox? aka Eztools? I would really like 1 tool that can do it all on all my cameras.. I know I am asking for a lot.. Main issue is I took some cameras from one of my POE NVRs and wanted to reset them all back to factory. Seeing I use a few different platforms I had to reset the Dahua/OEMs and then had to do the Hikvision in a different software and I would really like to do it in 1.. The Ailibi Toolbox gives the feel you could do it however couldn't even do batch resets so i had to use the IP Config, enter the right password, then click on the cameras I wanted to reset. Then open another program and do it again. Plus the Ip Config don't even find other brand devices that are not Dahua related.. The Eztools aka Alibi Toobox does find most of my cameras just don't want to do anything that isn't Alibi or Uniview related.. What tool is your go to?
Edit; Also so I am clear. I was able to reset first batch from the Alibi Toolbox.. Issue is that not all cameras are able to be accessed after either because it won't let the app talk to camera using admin and the ones that are in need of being Initialized to start with it was easy to just do it all from the IP config Tool.. That is why I am looking for one that can find all the cameras, Hikvision, Dahua and the OEMs of, Alibi and Uniview
