- Jan 16, 2015
- 526
- 27
so i installed a bosch pir sensor underneath dahua cam.sensor does a red blink then a quick double blink right after.it never stops doing that.according to the manual if the sensor light is off after a while then its working fine.i have it on a wood post.green lights dont come on.i enabled alarm in dahua cam settings and alot of emails come every 10 secs or so. i have it as nc.i also tried testing without alarm wires but still same thing.the stuff i'm using to power pir and cam is linked below.so is it working or is it defective? or user error?
dahua cam's blue wire(alarm in) connected to bosch 3.nc
gray(alarm in gnd) is connected to bosch 4.c
https://vimeo.com/182244135
http://resource.boschsecurity.us/documents/Bosch_OD850_Installation_Manual_all_2627312395.pdf
http://www.homedepot.com/p/Cerrowire-50-ft-18-5-Brown-Solid-Thermostat-Wire-210-1005BR/203172532
https://www.amazon.com/gp/product/B003CFATT2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00SM196AE/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B003MHUN7S/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
