- Oct 1, 2016
- 496
- 179
Background for my question.
Working on setting up my first camera system, have one camera now lol.
I have it connected to a PC running milestone, but it's an older pc, and doesn't seem up to the task.
So now I have to decide on whether to upgrade the PC, or get a Dahua NVR.
The NVR is appealing because the P2P function looks like it makes it really easy to connect my phone to the NVR, to be able to monitor while I'm away.
I know the answer will is VPN for security, but I spent some time last year trying to get VPN working with my Tmobile (slightly crippled ASUS) router and iphone/android phone for Domoticz. I finally gave up and used Weaved, which works fine for that.
So for that reason, I'd like to avoid VPN. My main problem was when it didn't work, I had no idea why. If I had the normal Asus router I could connect to the com port, and get more information, but can't do that with the tmobile version, so I was flying blind.
Back to my question.
Can I just just use Dahau P2P to make the connection, and will this be relatively safe?
Thanks
Randy
Thanks
Randy
