Hello, after 2 years by never log in into my NVR 4208-4KSK, today i tried to do it and i can't login with my admin user it say LOGIN FAILED, if i try to change the username it say INVALID USER NAME OR PASSWORD. My admin credentials are ok because i wrote them on a piece of paper.
I opened the cover of my NVR to look for a reset button, but there is no button. I also can't remove the battery from the motherboard, it seems to be welded. I tried some software like Configtool or other softwares that generate master passwords. Configtool say that my password reset has been disabled.
I can only access with gDMMS with a normal account that i made just to look live cameras on my smartphone (i can access it also using Chrome with the nvr IP).
What can i do to reset my admin password? Or reset completely my NVR?
Thank you.
Thank you.
