Is It Possible To Activate The Camera Wiper In Blue Iris
Baubas
Oct 16, 2017
167
24
I know I can trigger the wiper in SmartPSS but is it possible to trigger it Blue Iris?
I don't know what the API command to activate a Dahua camera's wiper is, but in theory if you could find out then you could configure Blue Iris to trigger the wiper when you activated a certain PTZ preset.
Look in the ptz menu of the speeddome. There you’ll find a option to activate the wiper.
Verzonden vanaf mijn iPhone met Tapatalk
@biscuit I think you misumisunderstood. Technically the wiper is activated. I'm trying to find a way to trigger it to wipe from within Blue Iris.
Why is everybody so excited about Blue Iris?
Use SmartPSS. It’s free and you don’t have to licenses...
To each their own :)
you dont need multiple licenses for BI, its simply 60 dollars (+10 for the mobile app)..not per camera....if you would actually use it you will see why...aside from the MANY more features, it is compatible with any rtsp/onvif camera, pss only works on dahua...pss is a joke toy compared to blue iris....
60 bucks for some software? No.
Let the chinese watch what i see..
its not about the chinese watching...its about the FEATURES most folks want/need...you dont have to spend the money if you are too cheap...60 dollars is nothing..you understand that most vms is 50-150 PER camera right? There is a reason they are used over pss...think a bit...
Then show me every feature in BI and a reason why I should buy it....
No, I am not a salesman...download the demo and see for yourself...you are a real special kind of stupid, huh...
Reactions: anijet
