- Mar 24, 2015
- 44
- 3
Hi guys,
I've been out for a few years, but before I was installing several Hikvision systems. It was the best option back then. I have never installed WIFI cameras, only wired Hikvision cameras.
Now I'd have a few places that would need 2-4 camera systems. They are with 4G/5G internet connection. Most without possibility to go wired. Furthermore, the routers might not support port forwarding. I guess this is not a problem anymore, or is it? I remember the last Hikvision systems I installed with hikconnect were pretty easy to install. I wouldn't like to mess up with the routers since the come from operators and there will be several different ones. Anyway, fast and easy installation is a benefit.
Some requirements for the set ups:
-Cloud system instead of NVR preferred (Internal sd-cards as storage)
-PIR sensor would be good / Alarm input
-waterproof necessary. Dome cameras preferred.
-WIFI range min. 20 meter, 50 meters preferred.
So should I even consider other brands? Dahua? Anything else?
