updates are still free...I'm considering buying BI and reading reviews on Amazon... one person posted that BI is now chargning a yearly fee for support & software updates (bug fixes).
Whats the full story?
thx
this was discussed previously here: https://www.ipcamtalk.com/showthread.php/8055-Blue-Iris-Annual-Fee
this is pretty standard stuff in the software industry; support and maintenance costs money and takes alot of time..
Yeah. That must be it. Lol
Blue iris is 100 percent stable..if it was not stable then you would not be using it. If you are having issues with stability its user error. I run 20+ blue iris machines. Zero issues. Why should the developer not be able to charge for support? Its 100 percent standard. Do you know that if you pay exacq 50 dollars PER CAMERA license they will provide 90 days of support and ONLY 90 days of updates. Yup...It's not standard for a one person company. Yeah Microsoft or Adobe but seriously, Blue Iris. This software is far from stable. I use tinycam on my tablet and it's far more stable.
User error. Plain and simple. IF you dont understand the difference between a tablet and pc, then you have a problem...also not the tablet is pulling and displaying the substream...try displaying the full res images of all those cameras on a table and record all at once...either your hardware is crap, or you are too lazy to read the help file or any threads here to properly setup the software. What processor are you using? what camera resolutions? are you running direct to disk?That shouldn't matter. Is your solution to just keep buying more hardware? My tablet handles these same cameras fine. A cheap tablet.
They are free for now..we are all able to download them without issue..your concerned about possibly having to pay 30 dollars for updates? really? look at milestone its free for 8 cams...I read the other thread - at least most of it. Whether something is 'normal' or not is irrelevant... I'd like to know what my exact cost will be the case before I make the purchase as I suspect v5 will be out next year. Still not clear if bug fix and minor releases will require a yearly fee. Guess I'll send an email to BI
