- Nov 10, 2014
- 428
- 38
Right now i'm running a TP-LINK TL-860 Advanced 8-port Cable/DSL Router, 10/100 mbps.
In Hikvision configuration I have bit rate set to constant. I have noticed I have to lower Max bit rate to 4096. Smoothing to 40 or cam locks up.
I just added 3 to my 4 today and noticed a couple was hanging and dropping out till I changed to those settings.
Blue Iris is set direct to disk, so it's not CPU and ram is low.
I did do a update to BI today to..
I have to admit, I definitely am a NEWB with both IP cams and Routers. It's not rocket science
All 7 are running and look good. But, i'm not sure if i'm getting the Maximum Performance out of them.. I will be adding at the least 5 more and was going to get a switch. But, if a Gigabit Router is needed first then I will have to get both.
Some advice would sure help!
- Chust
- Chust
