Is 8MP/4k resolution supported?
doczenith1
Mar 20, 2024
11
3
USA
I have a new Reolink 4K camera connected using ONVIF. tinyCam Pro is set to HW+. When viewing the camera status for the camera tinyCam is reporting 1280x720 resolution (ONVIF information is correct for the camera). If I switch the camera to 2560 x 1440 tinyCam will report 2560 x 1440. This is my first RTSP/ONVIF camera that I'm using with tinyCam. My other cameras are Wyze cams. I've made sure that "Main" is selected for streams and stream 1 is selected in the camera settings. Thanks for the help.
Reactions: Baja
I have some new information. I've added a new camera to my system. This new camera allows me to choose between H.264 and H.265 where the Reolink camera mentioned above only allowed H.265. With the new camera set to 4K and H.264 tinyCam does show 3840x2160 on the camera status page. So, it appears that tinyCam does support 4K but only when using H.264. The problem is that I believe the hardware I'm running tinyCam on does not support hardware acceleration for 4K H.264 resulting in an unusable frame rate.
