I currently charge $65 an hour and don't make sh** with this inflation and all!
Go for it!I currently charge $65 an hour and don't make sh** with this inflation and all!
Easily. Depending where you are you can charge more.I currently charge $65 an hour and don't make sh** with this inflation and all!
It is hard to find installers. I have 7 POE cams already "installed" temporarily However waterproofing and mounting are not my skillsets. ( Although after reading Tony R's fantastic article, I feel better!)
I have 3 PTZ and 4 non-PTZ. I got 2 estimates. Both were $3000 for the cams with the CAT-6 already installed and one long run already trenched. And I was unimpressed with their knowledge of how to mount correctly and address some of the difficulties with installation. And $600 install for 2 poles ( a bag of quikrete, a shovel and a pole).
It's about a 6 hour job and i would gladly pay $100/hour to someone who knew what they were doing in the Philadelphia region. The group here was far more useful.
You should be able to buy wall mount brackets that thread onto your PTZ domes. Then you mount a pole bracket to the pole using hose clamps and bolt the camera wall mount to that for a secure fit. Pole brackets work on poles as small as 2 inches in diameter.
[/QUO
Thank you!!
