Hello, I'm currently having an issue where I can't see my camera on my network, with or without power camera power brick supplied. The cable distance is 60 feet and there's no electrical interference, it's on the floor for testing right now. I've tried making 2 different 60 foot cable lengths and terminated multiple times with the same results.
Interestingly, when I took a 4 foot piece out of one of those 2 cables the camera posts fine to it's default IP and without the camera power brick. I've also noticed that the data transfer lights on the PoE is on almost constantly on the long cable lengths versus intermittent lights with the working shorter cable.
Any pointers/suggestions would be greatly appropriated! Thank you.
Camera from Andy
- DAHUA 2.7mm ~12mm motorized lens 2MP WDR IR Eyeball Network Camera IPC-HDW5231R-Z
Aliexpress.com : Buy Starlight 2.7mm ~12mm motorized lens 2MP WDR IR Eyeball Network Camera IPC HDW5231R Z ,free DHL shipping from Reliable network camera suppliers on Empire Technology Co., Ltd
PoE Switch from Andy
- DAHUA 8Port PoE Switch Unmanaged Two-layer industrial PoE switch Support IEEE802.3af, IEEE802.3at standard PFS3110-8P-96
Aliexpress.com : Buy DAHUA 8Port PoE Switch Unmanaged Two layer industrial PoE switch Support IEEE802.3af, IEEE802.3at standard PFS3110 8P 96 from Reliable ieee802.3af poe switch suppliers on Empire Technology Co., Ltd
Cable
- Monoprice Cat6 Bulk Bare Copper Ethernet Cable, UTP, Solid, Riser Rated (CMR), 500MHz, 23AWG (113674)
https://www.amazon.com/gp/product/B016YS99X0/ref=od_aui_detailpages00?ie=UTF8&psc=1
Connectors
- EZ RJ45 8P8C CAT6 Platinum Connector
https://www.amazon.com/gp/product/B01NCRL5NW/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
Camera from Andy
Cable
Connectors
