tigerwillow1
I tried 3 LED lights with the camera FOV about 80 degrees:
1. CMVision IR3, advertised coverage "60 to 80" degrees. The result was the same as in the first post of the thread, big hotspot in the middle and poor coverage at the edges.
2. CMVision IR40, advertised coverage "60 to 80" degrees. This one had the most even light distribution but didn't quite reach the edges of the camera FOV. With a 60 degree FOV camera this would be the best of the three.
3. Univivi U6R, 6 LEDs in a 3x2 array, advertised coverage 90 degrees. This one had a brighter center hotspot than the IR40 but covered to the edges of the camera FOV. Of the three, the best one for the 80 degree camera FOV.
However, the very best result was using two IR3s, each one angled out from the center of the camera coverage. This gives the best coverage to the FOV edges, without a nasty center hotspot. Using two IR3s takes the same power as the single Univivi U6R.
Power-wise, it pretty much one watt per LED with these three devices. All three have constant-power supplies, i.e. when the voltage goes up, the current goes down. I tested in the range of 8 to 15 volts. The IR3 was dead-on consuming 3 watts. The IR40 pulls about 3.4 watts, 0.85 watts per LED. The U6R pulled 6 watts, but doesn't have as large a usable voltage range. Its power draw tapered off when the voltage went below 12.
I found one more interesting thing on the following web page. Looks like using a diffuser with the lights can really help in some situations. I'd assume however that it reduces the maximum distance the light is good for.
IR Illuminators
IR Illuminators
