Hi,
I'm new to using IR illuminators and need some help.
I have this 850nm IR illuminator: BW 48 LED Infrared Night Vsion IR Light illuminator Lamp 40M for CCTV Cameras Security Camera (Big) : Amazon.co.uk: Electronics & Photo
It works well with my Nest Cam (Battery) and I can clearly see objects lit up with the additional IR light from the illuminator
However I also have a 850nm trail camera: Wildlife Camera WiFi Trail Camera Bluetooth 4K/48MP with 36pcs IR LEDs Infrared Night Vision Motion Activated IP66 Waterproof for Wildlife Monitoring, Outdoor Scouting & Home Security : Amazon.co.uk: Sports & Outdoors
The Nest Camera (Battery) detects the IR light from the trail camera very clearly, however the trail camera doesn't appear to detect much light from the IR illuminator? (i.e. If I point the trail camera directly at the illuminator it sees a bright spot where the illuminator is but not a glaring amount of light, however it doesn't appear to see any objects lit up by the illuminator any better than when the illuminator isn't used. I hope that description makes sense.
As they are all 850nm IR systems does anyone know why the trail camera wouldn't detect much IR light from the illuminator?
Thanks for any thoughts that might shed light (no pun intended) on the issue.
Fergal
Fergal
