Not sure how you'd go about it easily, as IR LEDs do have forward current limitations that can lower their life if exceeded.Has anyone experienced failures of the built in illuminators from running them too high?
Basically... Is there any harm in cranking the level up when it's beneficial?
If you need more IR why not install an outboard IR emitter?
They can be had in various sizes, watts, coverage angle and projected distance.
Floods?If there's recommendations on IR floors etc I'd welcome them as well
Well, how would you detect the default "fail"? Because LED lifetime is often specified as the time it takes to drop to 70% brightness. Will you notice?I've run most of mine at 100% and I've never had that fail on any.
