Not sure what happened to the attachment.If I set it to Day/Night, do I not run the risk, of the "Camera" thinking it is still Day, even after BI has turned LEDs off (and the camera then turns the LEDs on again?)
Anyway, I's give it shot, it'll either work or not, no harm done...set the camera to "day", hopefully BI will control the LEDs.
Any ideas how I might be able to retain BLC config from the camera, and/or pass those variables via Blue Iris? On a couple of my cameras I have the BLC offset to oneside to increase brightness in darker areas.
Magic, I knew I’d seen something like this.I'm still using this curl method, you can check out the post and see what you think:
Different settings to the Hik cams at sunrise/sunset using Blue Iris event schedule
As you know you can use Blue Iris event schedule to adjust brightness and few other settings to match with sunrise/sunset. Unfortunately you can not adjust WDR or noise reduction. Probably there is many ways to adjust those settings - here is one quite simple: 1. Install curl...www.ipcamtalk.com
