- Nov 28, 2014
- 83
- 4
Hey
Does anyone have experience with modified Webcams into IR only Cams or RTM IR Only Cams?
Thanks
Thanks
Why dont you just buy an ip camera with IR and a cut filter..Hey
Thanks
In your OP you said you want "IR only"...what are you using this camera for? if its for security you are better off with a network camera...yes you can use a webcam, but usb has limited distance as well as other drawbacks..I dont need an IP Can just an "normal" Webcam.
Why shuld i buy an Can with an IR when i dont need or want any?
Do you intend to place this webcam outside? if so how far from the pc? webcams are a poor choice for license plate capture...for good plate capture you need a really tight shot..I will use an Application who can read a licanze blade.
I dont understand, you are going to place a lens in front of the webcam?The range isnt any Problem i use some lense in front.
The only Problem is the Lights are replaced to LED who send no IR Light anymore.
thats my idea.you are going to place a lens in front of the webcam?
There are youtube videos that show you how to remove an IR filter from webcams...the day video will have poor color.When the cam have an ir filter the cant see ir light. so i need an cam who have not an ir filter to see the ir light.thats my idea.
i use such an webcam to play arround.There are youtube videos that show you how to remove an IR filter from webcams...
you must place an visible light filter in front to see the IR only light.the day video will have poor color.
What did you mean with?why dont you simply buy an 85 dollar hikvision and call it a night.
The range isnt any problem for me.How far will this webcam be from your pc?
A joke? do you have webcam that is better? You simply dont know what you are talking about. Not sure what you mean with respect to the led..the sensor are an joke and the led are cute note more...
my original 100€ Logitech Cam make very good Pictures during bad light conditions.do you have webcam that is better?
I Talk about 50m - 100m for that range i need an IR Laser like that:Not sure what you mean with respect to the led..
