Hi, I've done a bit of a searching but haven't hit the nail on the head, are any matte black paints particularly better than others for not reflecting IR?
Also has anyone found any particular canvas or similar (I was wondering if sound deadening foam or similar could work) or other plastics products which are non reflective that can be hung, draped over things etc. to reduce reflection. I realize camera angle and position modifications are always better, but sometimes a pole or object is in the way reflecting back some IR to the lens. Some hard plastic sheet for making better brows for some outdoor cams would be handy as well if anyone knows of non reflective type semi flexible sheet.
Thanks in advance.
Thanks in advance.
