ipux 303a
Welcome to the forum have you tried the two current options in the dropdown?
If none of those work you can try to enter the path manually, select mpeg on the top of the camera list and use this path.[TABLE="class: accesslog"]
[TR="class: even"]
[TD]http://IPADDRESS/cgi/mjpg/mjpeg.cgi
[/TD]
[/TR]
[/TABLE]
According to the ispy database the 1310 uses there two streams..the second one is the one i mentioned above...also make sure the ipaddress, user name and password are correct...
[TR="class: even"]
[TD][h=4]ICS-1310[/h][/TD]
[TD]JPEG[/TD]
[TD]http://IPADDRESS/cgi/jpg/image.cgi[/TD]
[TD]No[/TD]
[TD]None[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR="class: odd, bgcolor: #EEEEEE"]
[TD]MJPEG[/TD]
[TD]http://IPADDRESS/cgi/mjpg/mjpg.cgi[/TD]
[TD]No[/TD]
[TD]None
[/TD]
[/TR]
[/TABLE]
