IPCT IPCT 4MP bullet - $99 *SALE*
Mike
Staff member
Mar 9, 2014
3,040
3,047
New York
We are running a sale on this bad boy for only $99. Check it out. https://www.amazon.com/IP-Cam-Talk-Camera-IPCT-HFW2431S-I/dp/B07MD3VXVL/ref=sr_1_4?linkCode=sl2&linkId=4ebfadeea3ca2e263c4e8ad2fac81caf&m=AY4CT4V2U6LNL&marketplaceID=ATVPDKIKX0DER&qid=1555042788&s=merchant-items&sr=1-4
Tech Specs
  • 4 MP IR Fixed Bullet Network Camera POE
  • Up to 4 megapixel high resolution. Max. 2688x1520@30 fps
  • 4mm fixed lens
  • H.265, H.265+, H.264+, H.264 20dB
  • Wide Dynamic Range / 3D Digital Noise Reduction
  • DC12V & PoE (802.3af)
  • IR range: up to 30 m
  • Supports on-board MicroSD storage
  • IP67, IK10
  • Image Sensor: 1/3" Progressive Scan CMOS
  • Signal System: PAL/NTSC
  • Min. Illumination: Color: 0.01 Lux @ (F1.2, AGC ON), 0.018 Lux @ (F1.6, AGC ON), 0 Lux with IR
  • Shutter time: 1/3 s to 1/100,000 s
  • Slow shutter: Support
  • Lens: 4 mm @F1.6: horizontal FOV: 83°, vertical FOV: 45°, diagonal FOV: 99°
  • Lens Mount:M12
  • Adjustment Range:Pan: 0° to 360°, tilt: 0° to 90°, rotate: 0° to 360°
  • Day& Night: IR cut filter with auto switch
  • Wide Dynamic Range: 120 dB
  • Digital noise reduction: 3D DNR
  • Focus: Fixed
Smart Feature-set
  • Behavior Analysis: Line crossing detection, intrusion detection
  • Line Crossing Detection: Cross a pre-defined virtual line
  • Intrusion Detection: Enter and loiter in a pre-defined virtual region
  • Recognition: Face Detection
We only have 6 o these left and the sale ends on April 16, so act fast!
