ipcam web logon url
screen13
Jan 11, 2026
3
fort valley
Hi,
I have a yeskamo PTZ cam, 8 of them, I had used the web browser to configure some custom stuff in them, they have a server, but you cant just go to the IP, you have to add the page name and ext like logon.htm or whatever it is, I forgot what it was, any ideas on what to add after the ip ?
i tried default asp htm html, and index and logon and login and admin and setup etc etc,
They did not program a DEFAULT page in the web server app when the server is hit, you have to know the page file name, I dont know where I found it on the web a long time ago but it did work and I customized the cams, also, the TRACK MOVEMENT is not available in the yeskamo cams unless you can access this built in web app in the cam and enable it.
Q05-3MP Floodlight Security Camera​
the nvr comes hard coded with 172.x.x.x but i run the cameras across my home made wireless campus on 192.168.2.x and i change that in the web browser on each cam and it still connects to the 172.x.x.x nvr which will then accept the new IP addresses, this allowed me to put cams miles away, so i need to find this logon url page again as i had a few cams lose their programming and default back (temperatures outdoors i think)
I use openwrt and lots of netgear repeaers runnning the B.A.T.M.A.N. protocol for the campus effect, but I need to get inside these cams again and alter their 172.x.x.x ip's
THANKS
