P papaco n3wb Aug 18, 2022 4 0 Colorado May 24, 2024 #1 Is there a description of the differences and use cases for the three codeproject.ai Custom Models: ipcam-general, ipcam-generals, and ipcam-generaln?
M mailseth Pulling my weight Dec 22, 2023 151 104 California May 24, 2024 #2 This is one of the better descriptions I know of: Convert readme to a table of the models and labels by ahaverty · Pull Request #3 · MikeLud/CodeProject.AI-Custom-IPcam-Models @MikeLud I'm struggling to understand whether the combined model contains just light labels, or both light and dark, or whether animals has any dark models included. So instead of annoying you ... github.com
P papaco n3wb Aug 18, 2022 4 0 Colorado May 24, 2024 #3 Thanks ... good link. Still looking for a description of the "s" and "n" on the end of two ipcam-general variations.
M mailseth Pulling my weight Dec 22, 2023 151 104 California May 24, 2024 #4 Probably ’small’ and ‘nano’. What are the file sizes?
MikeLud1 IPCT Contributor Apr 5, 2017 2,484 4,592 Brooklyn, NY May 24, 2024 #5 mailseth said: Probably ’small’ and ‘nano’. What are the file sizes? Click to expand... That is correct, small & nano
P papaco n3wb Aug 18, 2022 4 0 Colorado May 24, 2024 #6 Thanks ... does small and nano refer to the fidelity of the model or the size of objects it can distinguish or other?
M mailseth Pulling my weight Dec 22, 2023 151 104 California May 24, 2024 #7 Roughly analogous to the speed, size, and accuracy you see in this table: GitHub - ultralytics/yolov5: YOLOv5 in PyTorch > ONNX > CoreML > TFLite YOLOv5 in PyTorch > ONNX > CoreML > TFLite. Contribute to ultralytics/yolov5 development by creating an account on GitHub. github.com
