IPC-T54IR-AS S3 Web Interface
Cor K Dikland
Apr 25, 2019
111
42
Ontario, Canada
Just got this camera today. I was originally led to believe this was the same as IPC-T54IR-ZE-S3 without the zoom but I cannot access the camera via web interface. I tried the obvious 192.168.1.108 as I would for my IPC-T54IR-ZE-S3 cameras but this camera is not using this IP. Instead it is using, on my wifi, 92.168.1.251. Either way, I can not connect to this camera. What do I need to do to setup this camera??
Did you do a hard reset of the camera?
Power up cam, press and hold the RESET button (located under the door for the SD card) for 10 sec to reset the camera.
Reactions: Rob2020
