I will be using the upcoming sale to add cameras to my back yard. I currently have no cameras there so I know I have a lot of options. The back of the house is about 55 feet across. There is a 14 foot x 14 foot alcove in the middle of the back wall. The back door is in the alcove. I will be getting a IPC-T5442T-ZE for the back door so I can get the narrowest fov needed. I considered getting either 2 more IPC-T5442T-ZE or 2 of the 2.8mm IPC-T5442TM-AS for backyard overview. Because there is a break in the roofline for the alcove, the cameras cannot be mounted side by side. They must be at least 12-13 feet apart so they need to have about a 110 degree fov to cover the back yard. I considering adding a 3rd overview camera in the middle. If I did that, I could use 2 of the 6.0mm 5442's and a 3.6mm 5442.
When looking over the sale list, I saw the IPC-T5449H-ASE-D2. The (world's first) review seems to indicate it's a pretty good camera with a good color/b&w mix. From the thread, it seems from the thread there were some issues in the beginning but they seem to have gotten sorted out with firmware updates. We keep the back porch (the alcove) lights on at night. Some of the light spills out to the side so anyone walking up would have a little bit of front lighting. It seems there are two versions of the hardware. Version 1 had a 1/1.8 and a 1/2.8 sensor and version 2 has two 1/1.8 sensors. The link on the sale sheet looks to point to a version 1 description. Is this a camera I should consider? I don't remember seeing this camera recommended in any of the other threads. Or should I stick with the "gold standard" 5442?
