We had this camera at work and it was very troublesome. So we retired it. Connection issues.
Rather than throw it away directly. I thought I'd give it a try to see if it could be revived.
I can see it with the Dahua config tool, but when I try to change the ip, I get a password error.
When I press the hard reset button on the camera, it never makes a sound and it appears to never reset.
Am I correct in thinking I should hold the reset button down and listen for the shutter to click before releasing the button?
Are there any other steps I can take?
Thanks.
Thanks.
