IPC-T5442TM-AS now shows different substream 2 options
lane777smith
May 11, 2022
151
78
texas
Hey guys. i have something weird happening so I wanted to know if anyone else has experienced this. I just purchased 3 of EmpireTech-Andy's Loryta branded IPC-T5442TM-AS cameras from Amazon. One 2.8mm and two 3.6mm versions. When i initially set them up, SubStream2 would only do 6 FPS @ 1080p, and 15 FPS @ 720P, so I configured all 3 of them for 15FPS @ 720P. Two days later as I was messing around with different resolutions and bit rates and i noticed Sub Stream 2 was allowing me to set 1080p to 26FPS (weird fps if you ask me) and 720P to 30FPS. I have no idea why as I've done no firmware updates. Anyone else experience this?
3.6mm versions are on:
System VersionV2.820.15OG001.0.R, Build Date: 2021-05-25
WEB VersionV3.2.1.1042333
ONVIF Version20.06(V2.9.0.979397)
S/N7E04BB2PAG24FCA
Algorithm Version1.0.3
Security Baseline VersionV2.1
2.8mm versions are on:
System VersionV2.840.15OG008.0.R, Build Date: 2022-02-18
WEB VersionV3.2.1.1140936
ONVIF Version20.12(V3.1.0.1064635)
S/N8B06AD3PAG28217
Algorithm Version1.0.7
People have experienced that if they were not using Internet Explorer,so make sure you are using Explorer and not Edge or chrome with IE tab. Sometimes windows will force Edge as well.
I've found that with an early production model of the 5442 versus a later production model. Some hardware changes were made between runs while the same firmware works for both.
