P paarlberg Getting the hang of it Apr 21, 2014 372 76 Jan 22, 2021 #1 Does anyone have the pinout or color codes for the iPC-T5442TM-AS? A critter decided he likes the camera more than I do and ate through the cable. I have about 6" of cable to work with adding a new rj45 jack. thanks
TonyR IPCT Contributor IPCT+ Member Jul 15, 2014 20,330 48,136 Alabama Jan 23, 2021 #2 From. Sept. 2020 ==>> IPC-T5442TM-AS RJ45 jack scorched - thoughts on how to replace? Reactions: aristobrat, paarlberg and Grn1z
P paarlberg Getting the hang of it Apr 21, 2014 372 76 Jan 23, 2021 #3 Thanks, I ended up re-soldering the wires, used shrink tubing, and then electrical tape over everything. It is working again Reactions: sebastiantombs
