IPC-T5442t-ZEB stopped detecting ivs tripwire in B&W mode
Dr Ian
Dec 14, 2016
60
15
ok so have 2 x IPC-T5442t-ZEB that have suddenly both stopped detecting ivs tripwire in B&W mode only? not changed any settings however they did get rebooted after a power cut.
tried rebooting everything, poe switch, cam etc but logic says its within the camera as daytime onvif are sent to bi as normal
would a super low manual shutter be the problem, if running custom shutter 0ms - 7 ms, so the image is quite dark?
Device TypeIPC-T5442T-ZEB
System VersionV2.840.15OG00D.0.R, Build Date: 2022-08-18
WEB VersionV3.2.1.1261216
ONVIF Version21.12(V3.1.0.1235054)
Algorithm Version1.0.7
Security Baseline VersionV2.1
Copyright 2022, EmpireTech all rights reserve
How dark? Can you post a pic?
It all depends on ambient light and/or IR. I run 0-8.33 on a lot of cameras...a few even faster
Reactions: JDreaming
