Yeah It is a little soft but much better than before. And I dont have artifacting/ oversharpening like I was getting. The camera is set up under an eve and it is angled so that when zoomed in, its centered for LPR on vehicles. All I did in those overview shots was zoom it out but kept the camera angle the same, hence the wood trim being in frame. The IRs are on the bottom. I know the eve will cause issues, but my main concern was LPRs and the general quality of the picture, which seems to be much better now. Ill play with focus and see if it improves moreStill looks soft/out of focus. I just noticed you have some wood trim or something across the top. That could be jacking with the focus and maybe even IR bounce at night. Are those IR's on the bottom of the turret or the top?
Can you have someone stand out in the center of the image and you hit autofocus and see if that makes it a little more crisp.
