IPC-T3241T-ZAS SMD 3.0 Latest new firmware IPC-HX3XXX-Leo_MultiLang_PN_Stream3_V2.800.0000000.37.R.220118.bin
chip_
Joined
Jan 15, 2021
Messages
21
Reaction score
14
Location
Oregon
Is this the latest firmware for this device?
Device Type IPC-T3241T-ZAS
System Version V2.800.0000000.14.R, Build Date: 2020-06-12
WEB Version 3.2.1.907431
ONVIF Version 19.06(V2.6.1.845551)
S/N 6L0499CPAG4F976
Algorithm Version 1.0.2
Security Baseline Version V2.0
Joined
Dec 30, 2016
Messages
815
Reaction score
632
Location
Somewhere in the space/time continuum
S/N 6L0499CPAG4F976
This is the latest, posted by @EMPIRETECANDY :
I have been running it for a couple of weeks now on 2 cameras, with no issues so far. But, as always use at your own risk. FWIW.
EMPIRETECANDY
IPCT Vendor
Joined
Nov 8, 2016
Messages
8,372
Reaction score
24,166
Location
HONGKONG
Fixed camera should be OK, normally PTZ/NVR has risk to flash if the FW version big time difference.
EMPIRETECANDY
IPCT Vendor
Joined
Nov 8, 2016
Messages
8,372
Reaction score
24,166
Location
HONGKONG
Hey guys
The SMD3.0 firmware i just update on the 1st page, welcome to download and upgrade!
Andy
civic17
Joined
Dec 7, 2018
Messages
178
Reaction score
60
Location
Canada
Hi Andy,
I was searching firmware for this model IPC-T3241T-ZAS. Currently my camera came with:
System Version V2.800.15OG003.0.R Build Date: 2022-01-18
WEB Version 3.2.1.1179647
ONVIF Version 20.06(V2.9.1.1000915)
At the dahua download center it has DH_IPC-HX3XXX-Taurus_MultiLang_PN_Stream3_V3.000.0000000.8.R.220429 and says compatible with IPC-HDW3241T-ZS-S2 .
Will this version work? Thanks.
EMPIRETECANDY
IPCT Vendor
Joined
Nov 8, 2016
Messages
8,372
Reaction score
24,166
Location
HONGKONG
Hi Andy,
They are not the same version, so just use the 2022 Jan version. In Aug will have a new fw to be released.
jmltech
Joined
Jul 4, 2022
Messages
24
Reaction score
33
Location
Colorado, USA
Hey guys
The firmware for the IPC-T3241T-ZAS has been released. Has some big update, try to update it.
Andy
Hi @EMPIRETECANDY
where is the firmware located from your July 20th, 2022 message? When I click on the link, it takes me to the product page at the IPCAMtalk store, but there isn't a tab or link for the latest firmware. You firmware on message #1 has a download link that says it has been deleted.
sebastiantombs
Joined
Dec 28, 2019
Messages
11,511
Reaction score
27,701
Location
New Jersey
jmltech
Joined
Jul 4, 2022
Messages
24
Reaction score
33
Location
Colorado, USA
Thanks. I cleared my web cache and re-logged into ipcamtalk. The download is now working. Previously it gave an error that the file couldn’t be found… hence the reason I thought the file was deleted.
this is the camera I won from Andy’s lottery. Just got it going this morning and am having problems with focusing. If I zoom in a little, the focusing goes all the way to one extreme, then back to the other, then tries going in and out about 5 times before settling, but not quite focused. Hoping a firmware update will help, since resetting to defaults a couple of times didn’t make a difference.
looney2ns
Joined
Sep 25, 2016
Messages
15,719
Reaction score
23,063
Location
Evansville, In. USA
Focus depends on your field of view, and what object it is focusing on.
You can use "Easy Focus" to tell it where to focus in the FOV.
jmltech
Joined
Jul 4, 2022
Messages
24
Reaction score
33
Location
Colorado, USA
I don't have an icon on the main 'live' screen for easy focus. The only two icons I have is a camera (for snapshot) and a speaker (for audio)
I did update the firmware... it was the same firmware that was already on the camera as shipped.
Under "Settings", "Camera", "Conditions", then on the "Zoom and Focus" tab there is a button on the bottom of camera view that has the same symbol as what you show, which says "Auto Focus". I tried that and it worked well. Thanks for the pointer.AutoFocus.jpg
Top
