Hi there!
I have had a IPC-T2431T-AS 3.6mm on my system for about 6 months and suddenly it went offline - I can see the device on my network but cannot get into the interface and can't send any commands to it through Config Tool (or any IP cam software for that matter). Anything I try results in 'connection failed'.
I've taken the camera out of service and used a different ethernet cable to connect directly to my laptop (w/ POE) and still having the same issues.
Is there anything I can do here? Any suggestions on troubleshooting? Or is this a common symptom of total device failure?
Thanks!
Ken
Thanks!
Ken
