IPC-HX4XXX-Volt_MultiLang_PN_Stream3_V2.800.0000000.10.R.191118.zip
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,111
26,556
HONGKONG
Here are the latest new firmware for the new 4.0 models(some fixed lens only).
Attention,
please double check before you make the update and make sure you are use the right firmware for right models which i list below ONLY. It has been tested by some members here, So we decice to release this version.
Models for
IPC-T5442TM-AS,
IPC-T5442TM-AS-LED
IPC-T5241TM-AS
IPC-HDW5541TM-AS
IPC-B5442T-ASE
Bugs fixed
Link for downloading.
Add a dropbox link, guys can try if have any problem, let me know.
Reactions: weigle2
Just updated my IPC-T5442TM-AS from V2.800.0000000.8.R, Build Date: 2019-09-02 to this one, without any problems. In fact the web-interface seems faster.
Just updated remotely, no issues so far but can't login to the cam as I'm not local and don't want to open ports. I'll check the IVS at least tripwire/intrusion once I get home. Also see if the triangle issue is back or not.
Just got home and no issues ans IVS seems to be fine and both cams.
I just updated from ver 190521 ,and IVS works fine, not triangle warning,
60fps now showing,
loitering and fast moving, etc now works,
queuing option in people counting
voltage detection
Reactions: weigle2
