I have a IPC-HFW5241E-Z12E as an LPR. It works really well EXCEPT for focus. Sometimes it works but sometimes the focus is quite a lot off. I followed the BlueIris way to switch between night and day.
Dahua day/night switch utility - DahuaSunriseSunset
What happens is that the focus is off, not every day but at least a couple of times a week. When I go to the camera's web portal I see focus values that I am almost 100% certain I didn't set (I have notes). When I set it back to my notes then everything is fine. The way I set focus is
1) Go to the Conditions tab (under Camera -> Conditions).
2) Select the Profile, e.g. Night
3) Switch to the Zoom and Focus tab.
4) Adjust the focus
5) Switch back to the Conditions tab
6) Hit Save
Then repeat for the other profile, e.g. Day. Initially I struggled that the setting would stick. Then they seemed to stick but every other day or so I get some random focus, neither what I set for day or night. I played with this so much I am out of ideas how to get this to work. What is strange is that both the Conditions tab and the Profile Management tabs (see attachment) have a selection for the Profile and a Save button. However, the Zoom and Focus tab does not. It appears to me that there is only one setting for Zoom and Focus (independent of the profile). But then why do I get those random numbers for focus every so often?
In case it matters, system version is V2.820.15HM000.0.R, Build Date: 2020-11-14
4) Adjust the focus
6) Hit Save
