IPC-HFW5231E-Z12E - LPR setup - Need Advice on equipment
tech101
1,548
2,299
SF BayArea, USA
First thing first so I am new and thank you everyone for a great place and site for researching a good camera.
So Upon reading lot of threads and looking results what user posted I decided to get the
IPC-HFW5231E-Z12E camera for LPR purpose.
I currently do not have any camera surveillance except some arlo pro 2 going.
So Since now I got the
IPC-HFW5231E-Z12E from andy I was wondering how should I go for the equipment and make it even future proof in terms of I will be adding some ptz and dome cameras in near future possibly 16 - 24 or even 32.
Buy one by one since it be very expensive to get it at one shot. So Where should I begin ? Should I buy a POE switch and run blue iris with openLPR software to get this lpr going or get the NVR which can support which one is better ? in terms of reliability and customization ?
Thanks and what are the min requirment for A PC to run this kind of setup say maybe with blueiris and openLPR for tagging..
Also since blueiris is on sale here for 49.99 is it a full version ? and if yes PC is a good idea instead of NVR than I will buy the Blueiris right away from here since its on sale.
And possibly a good POE switch soon.
Thank You!
So then is it a good switch apart from being loud ? Because I am thinking of putting it in garage anyways.
I would buy a switch from a known good US brand.
Okay, Thank you Fenderman I will order it from Amazon. Thank you so much Also is blue iris which is on sale is that the full version which is on sale ? I am thinking of buying it
For 8 port POE best product i have found is D-LINK DGS‑1008MP
Warning sometimes with brands like Dahua, the consumptions of cameras are wrong my camera 4K 12MP Dahua consumes at startup almost 20 Watts! I had breakdowns and in the end my POE injector was not powerful enough!
Always have power available when I choose an injector I take the total power and I multiply by at least 1.5
BICK
