Camera quit working a few days ago, finally got around to checking it out this afternoon. Found the connector all black inside, some water came out (more like mud), so obviously the weather "proof" connector did a great job of letting water in somewhere, and of course not letting it out. Using shielded cat5 which looks fine, except for the RJ45 which is very black and corroded as well.
Cleaned out the camera-side of the connector and tried it with a different cable, and it worked, just very intermittently. Tried cleaning it some more and one of the pins (#4 I believe) came out, so I believe this was the one supplying POE since now the camera won't power up (unless using a 12v p/s), and no ethernet connection anymore.
I'm quite sure the camera is still good, just the connector is bad. I cut the cable and find 6 conductors. Matched which pins they go to except pin #4, which could be any of the wires except the grey one that is pins 7 and 8.
Colour code:
1 brown
2 purple
3 orange
4
5 yellow
6 blue
7 grey
8 grey
Of course with 6 conductors this is different colour coding from the normal RJ45 connection whether it be T568 A or B.
Hate to burn up a working camera by dumping POE 48v into the wrong wire... Has anyone had one of these apart? Next step is trying to dissect the original camera connector without messing it up so I can tell what connects to the #4 pin. If anyone has this pinout it would make this a lot easier...
Should mention I usually add dielectric grease to these connectors so water can't get into them. This one I had not, remembered I had run out of the stuff and needed to come back and re-do that one, and forgot. Why mess with it if it works eh?
Belated happy Thanks Giving all!
Colour code:
1 brown
2 purple
3 orange
4
5 yellow
6 blue
7 grey
8 grey
