IPC-HFW1831E New Firmware DH_IPC-HX2(1)XXX-Sag_EngSpnFrn_NP_V2.622.0000000.8.R.180731.bin
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,110
26,554
HONGKONG
Hey guys
Get one latest new firmware for the IPC-HFW1831E.
Cams suit these models.
DH(With dahua logo)-IPC-HFW1831EP(P means PAL )-0280B(LENS 2.8MM), new firmware will use PAL and NTSC on 1 , this can make the user easy to find the firmware, i always release the top new FW for you guys, lol.
DH-IPC-HFW1831EP-0280B,DH-IPC-HFW1831EP-0400B,DH-IPC-HFW1831EP-0600B,DH-IPC-HFW1831EN-0280B,DH-IPC-HFW1831EN-0400B,DH-IPC-HFW1831EN-0600B,IPC-HFW1831EP-0280B,IPC-HDBW2831RN-ZAS-3711,DH-IPC-HDBW1831RP-0280B,IPC-HFW1831EP-0400B,IPC-HFW1831EP-0600B,IPC-HFW1831EN-0280B,IPC-HFW1831EN-0400B,IPC-HFW1831EN-0600B,DH-IPC-HDBW2831RP-ZS-3711,DH-IPC-HDBW2831RP-ZAS-3711,DH-IPC-HDBW2831RN-ZS-3711,DH-IPC-HDBW2831RN-ZAS-3711,IPC-HDBW2831RP-ZS-3711,IPC-HDBW2831RP-ZAS-3711,IPC-HDBW2831RN-ZS-3711,DH-IPC-HDBW1831RP-0400B,DH-IPC-HDBW1831RP-S-0400B,DH-IPC-HDBW1831RP-S-0600B,DH-IPC-HDBW1831RN-S-0280B,DH-IPC-HDBW1831RP-S-0280B,DH-IPC-HDBW1831RP-0600B,DH-IPC-HDBW1831RN-0280B,IPC-HDBW1831RP-S-0280B,IPC-HDBW1831RP-0400B,DH-IPC-HDBW1831RN-0400B,DH-IPC-HDBW1831RN-S-0400B,DH-IPC-HDBW1831RN-0600B,DH-IPC-HDBW1831RN-S-0600B,IPC-HDBW1831RP-0280B,IPC-HDBW1831RP-0600B,IPC-HDBW1831RN-0400B,IPC-HDBW1831RN-S-0400B,IPC-HDBW1831RN-0600B,IPC-HDBW1831RP-S-0400B,IPC-HDBW1831RP-S-0600B,IPC-HDBW1831RN-0280B,IPC-HDBW1831RN-S-0280B,IPC-HDBW1831RN-S-0600B,DH-IPC-HFW2831TN-ZAS-3711,IPC-HFW2831TP-ZS-3711,IPC-HFW2831TP-ZAS-3711,DH-IPC-HFW2831TP-ZS-3711,DH-IPC-HFW2831TP-ZAS-3711,DH-IPC-HFW2831TN-ZS-3711,IPC-HFW2831TN-ZS-3711,IPC-HFW2831TN-ZAS-3711
There is an odd issue where the bitrate can be customized to a value above what the camera is specified to run, but it reverts to the max bitrate (8192kbps) upon a reboot of the camera and then changes the "customized" bitrate to a maximum value different than before, lol.
To be fair, this is exactly what the Pro/Eco-savvy cameras do as well. So it's not isolated to this camera or it's firmware.
(Was 15104kbps before a power outage....very strange...)
All, can this be used with the Lorex equivalent LNB9232s ? If not, anyone know where you can download the Lorex FW for offline installs for this camera, the NR908x and the LNB8963 Vari camera ? @EMPIRETECANDY any thoughts on this ? Thanks
