I currently have he 4MP Dahua IPC-HDW5442T-ZE / IPC-T5442T-ZE installed. There is a review by Wildcat_1 praising the quality of the 8MP Dahua IPC-HDW5842T-ZE / IPC-T5842T-ZE. I'm intrigued to see how it handles for my situation at night.
A quick search on Dahua turned up:
Dahua IPC-HDW5842T-ZE-S2
Dahua IPC-HDW5842T-ZE-S3
Running through the specs, the difference between the S3 vs S2 are:
FPS: 25/30 vs 30
SD: 512GB vs 256 GB
ROM: 4GB vs 128MB
RAM: 2GB vs 1GB
Min Illum: [email protected], .0004@ F1.8 [vs] .004@ F1.4, [email protected]
Max Aper: F1.8 vs F1.4
Close Focus: 4.92ft vs 3.3 ft
SMD3.0: Yes vs No??
Gain Control: Auto vs Auto + Manual
Power (POE): 9w vs 7.3w
If I'm understanding the above correctly it appears the S3 model is better, at least w/ RAM/ROM ;P . I couldnt confirm if EmpireTechAndy has this model in stock (still waiting on a reply). The Amazon item he sells here doesnt state which series.
FTR, I prefer purchasing through Amazon rather than Aliexpress for piece of mind.
FPS: 25/30 vs 30
SD: 512GB vs 256 GB
ROM: 4GB vs 128MB
RAM: 2GB vs 1GB
SMD3.0: Yes vs No??
