- Sep 20, 2017
- 696
- 554
Ah OK I see now. Literally no difference...hmm. guess I will hold off on upgrading since it breaks my other cams.
Nope....almost no change now. Here is h.264
There is a new update out. 4.6.4.3. I wonder if this has any other fixes for h.265.
Those were my setts.Set max bitrate to 2048 (Dahua menu) and take 265H . I have the same this setting solved my problem
Just finished my first 1hr clip using 4.6.4.3 and not seeing much difference. The clip recorded fine, but with no reduction in size I rather stick with h.264. KEEP in mind I am using a I5 3rd gen. processor that doesn't support h.265.....so maybe it can't write direct to disk as it should. I would think it would only involve decoding. I asked Ken this and all I got was try the 4.6.4.3.
Did it once with the new soft but after that it was fine...Now 4.6.4.4 is out. I'm going to try to update and see what happens.
I had an idea. Not sure if it's correct but I thought I would share.
H.264: 24~9472Kbps H.265: 14~5632Kbps
These are the bit rates for the 5231R-Z. H264 dropdown for me maxes out at 8192kbps and H265 maxes out at 4096. So let's say I had it sent to h264 at 8192 well when I switched to h265 I would be forced to a max of 4096 (or slightly higher with custom setting) which would be the same quality as h264 at 8192 (that's a guess). So maybe space saving comes from being able to use a lower bitrate or getting better quality with the same bitrate. It would make sense that MPxFPSxbitrate gives you the same size file despite the encoder setting. So wouldnt it make sense that you did not change Megapixels, FPS, or bitrate so of course your file size remained the same! I think that makes sense?
Anyway I upgraded now. Running H265 now. Will report back tomorrow.
Same here. It works fine here with h265 except for the 30frames which I also believe is caused by the new dahua firmware.
Seems there is no beta testing for Dahua firmware before release.
or email supportWell I had the same grey screen issue appear today for about 2 seconds. I had some Jehova witness people knock on my door today and when they were walking away the screen went blurry for a sec. I'm on the current version of Blue Iirs (4.6.4.6). Guess I should just revert to h264 and be done with it.
Is the grey/black-screen bug for sure fixed in the latest BI (4.6.4.11)? I reverted back to 4.5.8.5 due to this bug. (I have not yet updated the Dahua firmware for the camera btw).
