Ok, thank you both again. So, these cameras are for a ranch style home, and each house corner can be easily accessed with an 8 ft step ladder. I have run 2 new cat 7 Ethernet lines and also two 12 volt lines (if needed) to each corner. I may only use one set per corner, but wanted the flexibility of 2 per corner, if I thought it was necessary. I may need to reconsider the dome option, I didn't anticipate any movement (pan or tilt), but only once in a great while, maybe every couple months, I would like the flexibility to pan or tilt remotely. That would still be accomplished remotely through the camera parameter options, correct? (That was my understanding, please correct me if I am wrong.) Basically, I don't have to get the stepladder, when I visit my Mom to adjust angles (pan or tilt) with it.
If I go w/ the bullet, I could put 2 per corner at different positions. That would then bring me back to the 4mp / (1/1.8" sensor) and then decide on which varifocal lens options = (2.7-12 / 8-32 / 8-80) Guessing would use mainly 2.7-12, and maybe a select few of 8-32 or 8-80.
Maybe those that have the dome version, can comment on if they wish they had the bullet version, ha....
I'll attach each bullet varifocal option, in case someone wants to see them.
