IPC-HDBW5441F-AS-E2
betogar
Apr 16, 2017
25
5
Hey Andy
Any news of this camera? looks interesting
Camera
Image Sensor
1/2.7" CMOS
Max. Resolution
2560 (H) × 1440 (V)
ROM
128 MB
RAM
1 GB
Scanning System
Progressive
Electronic Shutter Speed
Auto/Manual 1/3 s–1/100,000 s
Min. Illumination
0.005 [email protected] (Color,30 IRE)
0.0005 [email protected] (B/W,30 IRE)
0 lux (Illuminator on)
S/N Ratio
Illumination Distance
30 m (98.43 ft) (IR)
Illuminator On/Off Control
Auto
Illuminator Number
16 (IR LED)
Pan/Tilt/Rotation Range
Pan: 0°–355°
Tilt: 0°–65°
Rotation: 0°–360°
Lens
Lens Type
Fixed-focal
Lens Mount
M12
Focal Length
2.8 mm; 3.6 mm
Max. Aperture
F1.6
Field of View
2.8 mm: Horizontal: 95°; Vertical: 52°; Diagonal: 114°
3.6 mm: Horizontal: 78°; Vertical: 41°; Diagonal: 94°
Iris Control
Fixed
Close Focus Distance
2.8 mm: 1.1 m (3.61 ft)
3.6 mm: 1.7 m (5.58 ft)
DORI Distance
Lens
Detect
Observe
Recognize
Identify
2.8 mm
63.6 m (208.66 ft)
25.4 m (83.33 ft)
12.7 m (41.67 ft)
6.4 m
(21.00 ft)
3.6 mm
85.4 m (280.18 ft)
34.2 m (112.20 ft)
17.1 m (56.10 ft)
8.5 m
(27.89 ft)
Smart Event
IVS
Abandoned object; missing object
Professional, intelligent
IVS (Perimeter Protection)
Intrusion, tripwire, fast moving (the three functions support the classification and accurate detection of vehicle and human); loitering detection; people gathering; parking detection
SMD 3.0
With intelligent algorithm, Dahua Smart Motion Detection technology can categorize the targets that trigger motion detection and filter the motion detection alarm triggered by non-concerned targets to realize effective and accurate alarm.
Face Detection
Face detection; track; snapshot; snapshot optimization; optimal face snapshot upload; face enhancement; face exposure; face snapshot set as face or one-inch photo; snapshot strategies (real-time snapshot, quality priority and optimization snapshot); face angle filter; optimization time setting
People Counting
Tripwire people counting and people counting in area; generating and exporting report (day/month/year); queue management; 4 rules can be set for tripwire, people counting in area and queue management
Smart Search
Work together with Smart NVR to perform refine intelligent search, event extraction and merging to event videos
Video
Video Compression
H.265; H.264; H.264H; H.264B; MJPEG (Only supported by the sub stream)
Smart Codec
Smart H.265+; Smart H.264+
AI Coding
AI H.265; AI H.264
Video Frame Rate
Main stream: 2560 × 1440 @(1–25/30 fps )
sub stream: 704 × 576 @ (1–25 fps)/704 × 480 @ (1–30 fps)
third stream: 1920 × 1080 @ (1–25/30 fps)
Stream Capability
3 streams
Resolution
4M (2560 × 1440); 3M (2304 × 1296); 1080p (1920 × 1080); 1.3M(1280×960); 720p (1280 × 720); D1 (704 × 576/704 × 480); CIF (352 × 288/352 × 240)
Bit Rate Control
CBR/VBR
Video Bit Rate
H.264: 32 kbps–8192 kbps
H.265: 32 kbps–8192 kbps
Day/Night
Auto(ICR)/Color/B/W
BLC
Yes
HLC
Yes
WDR
120 dB
Scene Self-adaptation (SSA)
Yes
White Balance
Auto; natural; street lamp; outdoor; manual; regional custom
Gain Control
Auto
Noise Reduction
3D NR
Motion Detection
OFF/ON (4 areas, rectangular)
Region of Interest (RoI)
Yes (4 areas)
Image Stabilization
NA
Smart Illumination
Yes
Defog
Yes
Image Rotation
0°/90°/180°/270°
Mirror
Yes
Privacy Masking
8 areas
Audio
Built-in MIC
Yes
Audio Compression
PCM; G.711a; G.711Mu; G.726; G.723
Alarm
Alarm Event
No SD card; SD card full; SD card error; network disconnection; IP conflict; illegal access; motion detection; video tampering; tripwire; intrusion; fast moving; abandoned object; missing object; loitering detection; people gathering; parking detection; scene changing; audio detection; voltage detection; external alarm; face detection; SMD; people counting in area; stay detection; people counting; security exception
Network
Network Port
RJ-45 (10/100 Base-T)
SDK and API
Yes
Cyber Security
Video encryption; Firmware encryption; Configuration encryption; Digest; WSSE; Account lockout; Security logs; IP/MAC filtering; Generation and importing of X.509 certification; syslog; HTTPS; 802.1x; Trusted boot; Trusted execution; Trusted upgrade
Network Protocol
IPv4; IPv6; HTTP; TCP; UDP; ARP; RTP; RTSP; RTCP; RTMP; SMTP; FTP; SFTP; DHCP; DNS; DDNS; QoS; UPnP; NTP; Multicast; ICMP; IGMP; NFS; SAMBA; PPPoE; SNMP
Interoperability
ONVIF (Profile S/Profile G/Profile T); CGI; P2P; Milestone
User/Host
20 (Total bandwidth: 64 M)
Storage
FTP; SFTP; Micro SD card (support max. 256 GB); NAS
Browser
IE: IE8 and later
Chrome
Firefox
Safari: 12 and later
Management Software
Smart PSS; DSS; DMSS
Mobile Client
iOS; Android
Certification
Certifications
CE-LVD: EN 62368-1;
CE-EMC: Electromagnetic Compatibility Directive 2014/30/EU;
FCC: 47 CFR FCC Part 15, Subpart B;
UL/CUL: UL62368-1 & CAN/CSA C22.2 No. 62368-1-14
Port
Audio Input
1 channel (RCA port)
Audio Output
Alarm Input
2 channels in: 5mA 3V–5 VDC
Alarm Output
2 channels out: 300mA 12 VDC
Power
Power Supply
12 VDC/PoE
Power Consumption
Basic: 3.1 W (12 VDC); 4 W (PoE)
Max. (H.265 + IR on + intelligence+ WDR): 6.6 W (12 VDC); 8 W (PoE)
Environment
Operating Temperature
–40 °C to +60 °C (–40 °F to 140 °F)
Operating Humidity
≤ 95%
Storage Temperature
Protection
IP67; IK10
Structure
Casing
Metal
Product Dimensions
66.2 mm × Φ122.0 mm (2.61" × Φ4.80")
Net Weight
0.52 kg (1.15 lb
Looks like a 4MP version of the original booby cam on essentially the same sensor size. The 4MP does add AI to it. Wonder if both cams can use IVS at the same time.
While this camera does fill a niche role and I do have two of them, if it is on the same CPU as the 2MP, then this one will struggle. And run even hotter than the 2MP.
Do you know if any of the limitations of the 2MP version has been addressed in this version?
Following...( that joker Wittaj)
I got a couple of these cams yesterday and the issues with the 2mp version have been addressed--i.e., IVS and AI features work on both channels and the camera temperature is normal, not hot. The form factor is smaller than the 2mp version. The lenses are closer together and the camera footprint is the size of the wedge cams. When outer case is removed, the lenses do not require a screw to be loosened to adjust the lens position. Only gripe is that the firmware (dated July 30, 2021) requires a plug-in for both IE and Chrome. But the camera runs very stable and with the smaller form factor, I think will be a very attractive option to get two cams from one.
That is awesome! Sounds like they took all the "complaints" to heart and produced a camera that is very capable and fills a great niche and need for many of us. Time to save to replace my existing ones LOL.
Yep. I'm looking forward to reducing my Deepstack CPU usage for the 4 2mp cams (2 cams x 2 sensors) that I'm replacing these with.
Interesting looking camera. Now I just need to create a situation that this camera will provide a solution for, so I can create a justification for the head CFO to approve expenditures for my personal R&D projects......
Any ballpark idea on price, Andy? Any reason it wouldn't be viewable on MAC OS?
This model has been released, here is the review.
