1) So, I bought this cam, in BI I'm trying to use the Zoom/Focus commands and they work, but in some res/Mbit config they are so sloooow: it can wait upto 20s to update the pic! In the browser instead all is fast.
I.e. @max Res 2592x @20fps 10240Mbit
instead if I put down the res and the Mbit, it's ok
i.e @res 1080 @25fps 8192Mbit
Why this in BI? Is there a way to make it work fast also at max res/Mbit?
2) I'd like to use the presets to use at least 2 zoom levels, has this cam no presets?
3) maybe should I go with cgi-bin, I found this command here:
Dedicated License Plate Cam project
is there a complete list of commands? I found some Dahua http API pdf, but I found no commands like that... They have only FocusNear, FocusFar and similar.
