I have just bought this camera from Andy. There will probably be enough light for this to work without using the built-in warm lights, plus there are LED floodlights that come on with a motion sensor, which will help.
However, as a Home Assistant user, I'm interested to see if there is a way to turn on the warm light using the API?
I can get the light status using , but can't seem to change the lighting mode between Manual, Auto and Off.
I though that I could send the command , which returns an "ok", but does not seem to actually change the mode.
Has anyone used the API to do this successfully?
