Starting a new thread on this topic as I have been briefly discussing this in a few other threads a while ago with some suggestions but with no conclusion.
My setup is:
BI server:
Dell Optiplex 3050, i5-6500/intel graphics 530 with 16gb ram, 500gb ssd only for OS, 3tb seagate surveillance disk for recordings (new, stored, alerts)
Win10 pro clean install, latest BI v5.
Network: tp-link omada enterprise poe+ switches interconnected with fiber sfp
Cameras on a isolated subnet/vlan.
Cameras: 1 IPC-Color4K-T, 1 5442 and 3 older hikvisions. Total 5 cameras
I have read the wikis on this site and did all the applicable optimizations/ "tweaks", including substreams for all my cameras and direct2disk recording. (continous+trigger)
All cameras are Constant bitrate, 15fps (both main and substreams) and i-frame set to 15.
My issue is that after I installed and set up my color-4k-t it is stuttering/pausing every second. This is when viewing live or recordings in Bi console or even UI3.
My other cameras are also behaving likewise when my ipc-color4k-t is enabled but not nearly as bad. If I disable the 4k-t, the other cameras are smooth.
-If I disable substreams on the 4k-t, everything is fine but I want to be able to keep that for obvious reasons.
-If I increase the i-frame interval to 30, the stuttering is every 2 seconds and so on.
-Videos exported to mp4 from blue iris is also perfectly smooth.
-I have tried factory defaulting the camera (3times, using IE)?and installing latest firmware with exact same result
-I have tried to reconfigure it from scratch in Blue iris and increased the buffer/cache to 40mb (can't remember the name, I am away from the server atm)
I don't believe this is network related, because if I view the 4k-T's full resolution RTSP stream directly in VLC player on same computer it is perfectly smooth. (VLC has a 1000ms buffer)
I have seen in other threads people are experiencing similar symptoms using 4k cameras but none of them seems to be resolved.
I am wondering if this could be a pc hardware issue? My BI server is usually running around only 10-12% cpu load and memory less than 30%.
My next step is to try BI with this camera on a more powerful computer...
For those of you that successfully run this specific camera with Blue Iris (1or more), what are your hardware specs?
My setup is:
BI server:
