IPC Camera doesn't work
0vereem1
Sep 2, 2019
3
3
Poland
Hello everyone!
I've a problem with one of my six IPC Camera. After electricity shutted down one camera wont start.
IR LED are working, then I use IPCsearch to see whats happened, camera had a default IP and everything but I cound't connect to camera by IE. I notited one detail. In firmware name in this camera which doesn't work there is "_mini" behind firmware, maybe because of that? Attache! I tried to find firmware to reinstall it but there is no. Hard to find it "s2l55m_imx124_w_6.1.34.1". How to contact Herospeed? There is no e-mail or anything.
Best regards
Michal
Can you do a hard reset ? It may be a button inside the camera or two contacts that need to be shorted together. The power surge may have fried the camera. I know nothing about Herospeed brand.
Reactions: 0vereem1
I didnt try hard reset by pressing button inside, didnt take off camera from roof yet. Herospeed is software company I believe from where my camera has software but its hard to contact them to get software
A google search yields a slightly newer version of that firmware - and it may be a valid match.
Just be sure to use the correct download link.
Download Ambarella S2L55M IMX124_X Camera Firmware 6.1.44.3 for OS Independent
Thanks a lot!
I downloaded it and upgrate the camera and its working!
Anyway IPCSearch now shows firmware version not 6.1.44.3 but like it was before 6.1.34.1 but anyway its working like before, "_mini" dissappear from the firmware version and everything its perfect!
Kind regards
Michal
Good result!
That's a bit odd.
Looking in the firmware file - the 'Ver.ini' file shows :
Code:
[VERSION]
sofvar=S2L55M_IMX124_W_6.1.44.3
But the important thing is that it's working again.
