IPC-B54IR-Z4E-S3 optimisation for night time LPR
Nov 13, 2024
4
Uk
apologies if this is in the wrong forum - mods please point me elsewhere if appropriate
following all the recommendations in these forums I've bought a IPC-B54IR-Z4E-S3 from andy, specifically to dedicate to the job of LPR.
Its located at a height of about 4m (adjacent to an upper floor window of 2 storey UK house) about 30m from the target spot. Angle of about 30 degrees to the traffic.
Its on full zoom.
In the day its giving good results (depending on vehicle speed , mostly they are slow because they have to be)
In the night I have blown out reflection on the plates.
I only installed this cam yesterday so still learning how to tune this camera- in order to get a headstart, is there a set of best practice settings for a dedicated LPR use case?
I've already dialled the shutter speed down to 10msec, should I go lower? what else to tweak?
these are UK plates.
thanks
so I now have for Exposure set6tings:
1770331446135.png:
not clear to me how to use that gain setting? what are the two values for? on other cameras I only have one value for gain.
I've now got a much darker picture which I know is expected - not had any cars yet (late night bad weather everybodys hiding) so will leave it recording overnight and see
I wonder sometimes if it might be worth it for some to spend the extra money on an actual lpr vs trying to make something that’s not meant for it do the job. I guess it comes down to what is your time worth
Actually you have to go thru the same process to some extent. The only difference is the LPR can read and log the plates.
In the 22 years I’ve been doing this for a living, I’ve never spent the time you guys do making adjustments to an LPR as you guys have just posting about, let alone the actual keyboard time making a non lpr do the job.
I’ve said on this forum that a lot of you guys know a lot more about nighttime optics and settings than me. I wouldn’t consider it a good business model if I had to spend that amount of time to capture a plate
And dedicated LPR cameras are usually more expensive for the convenience of the logging plates automatically.
Again, what’s your time worth?
Most of you posting on this site should be doing this for a living. I wish I had a bunch of you here in the Midwest
