Just got this Amcrest IP8M-2796EW-AI. Working to get it setup. I can't seem to get the Key Frame above .50 on the Main Stream. The Sub Stream is working great.
I'm using Blue Iris 5.7.9.12. Camera firmware is up to date.
Current Settings:
Encoding: H.265
Smart Codec: Off
Resolution: 3072x1728
Frame Rate: 15
Bit Rate Type: CBR
Bit Rate: 1344 (customized)
Frame Interval: 15
I've adjusted all of these settings in almost every combination. I have another IPCam working fine at 15FPS 1.00 Key Frame.
Any help is much appreciated!
Current Settings:
Encoding: H.265
Smart Codec: Off
Frame Rate: 15
Bit Rate Type: CBR
Frame Interval: 15
