Hi All,
I am trying to integrate a blueiris solution running a pretty hefty server config.
I am thinking of either an i7 extreme or XEON windows 8.1, 16GB ram with some sort of RAID on it.
The cameras that I have from a local supplier are as follows when it comes to the specs.
CAMERA
I am concerned about network compatibility with Blueiris? These cameras support on OnVIF, does anyone have any ideas on what else I should be looking for (besides the tested cameras matrix) on the blueiris site? (See attached spec sheet)
Thanks,
DC
Los Angeles, CAView attachment Camera_Spec.pdf
CAMERA
- Sensor Aptina 1/3” WDR CMOS
- Max Resolution / FPS 2048×1536 / 30fps
- Min. illumination 0.5Lux @ F1.2 (Color) (0 Lux IR LED On)
- Day / Night True Day / Night with ICR Filter.
- IR LEDs 3 High Power IR LED & 14 SuperFlux LED cover up
- to 100ft
- Lens 3.3-12mm Vari-focal IR Corrected / ( Optional
- 9-22mm & 5-50mm)
- Video Output Service RCA Video output with IP OSD via bottom
- access panel
- Electronic Shutter Auto / User 1/5 - 1/50, 0000; 50/60Hz software
- selectable.
- Compression H-264 High Profile (Support Baseline Profile) / MJPEG
- Bit Rate (CBR/VBR) Stream1 50Kbps - 12Mbps ; Stream2 10Kbps -
- 6Mbps ; Stream3 (Fixed)
- Quality Setting 1 - 9 (9 Highest)
- Multi- Streaming User setting of Stream 1/2 at supported Resolutions,
- Stream3 MJPEG Stream
- Brightness / Sharpness Variable 0~100 / 0~100
- Gain Control Auto / Fixed 8~102db
- Orientation Horizontal Mirror / Vertical Flip
- Text Overlay Time / Date / Camera / Custom OSD
- Masking 5 User defined masking areas < 8% of total picture
- Ethernet 1 Ethernet (10/100 Base-T) RJ-45 Connector
- TCP/IP IPv4 / IPv6 (DHCP / Fixed)
- Compliance Onvif v2.2 Profile-S Listed
- RTSP Video Standard RFC2326, Support QuickTime / VLC Player.
- User security authentication (Enabled / Disabled)
- Web Language English, Chinese, Russian, Polish, (European Lan- guages coming 2013)
- Recording Simultaneous Local Micro SD Memory, Remote FTP server, TCP/
- UDP CMS, RTSP connection (stream 1,2 or 3)
- Network Protocols: HTTP, TCP/IP, UDP/IP, RTSP, FTP, DHCP, NTP, PPoE,
- NTP. Unicast and Multicast supported.
- Memory Card Slot Internal memory card supports Max 64GB. Supports
- Edge Recording
- Input / Output 1 × RCA Input / 1 × RCA Output @ 1v Line Level
- Audio Compression G711 A-Law, G711 U-Law, RAW_PCM
- GENERAL
- Power 12V DC @ 840mA (IR LED On) / PoE Class 3
- Temperature Operating: 14°F to 131°F (-10°C to 55°C) Storage:
- -4°F to 140°F (-20°C to 60°C)
- Operating Humidity 10% - 85% RH
- Approvals CE / FCC / RoHS Compliant / IP66 / IK5
- Product Dimensions 377 × 110 mm (13.75” × 4.25”)
Thanks,
DC
