i have securitycameraking's "TRIDVR-ELE16M CM 16 Channel" tribrid using bnc analog cams and want to get 2 IP cams for my garage.
i'm looking at either of these two for my garage...the bullet one in particular due to the reviewers with issues mounting the "dome" version.
1 Megapixel Indoor/Outdoor IR Network IP Cameras:
see link for image/specs: http://www.securitycameraking.com/ip-network-security-cameras-228-ctg.html
Dome Product# IPOD-EL1MPIR50-E
Bullet Product# IPOB-EL1MPIR50-E
anyone used either of these IP cams? they would be relatively "good" for a garage, yes? they will be replacing two foscam FL8910w
tia
wb
tia
wb
