Hi, i have over the pas years has problems with my 2 wired reolink cameras. first i had 2x RLC-511 POE Cameras
They are connectet to a synology DSM 218+ with 4gb ram and DSM 7.0
i have a fiber connection 500/500mbit and that works like a charm, speed test says 520/517mbit connection and 1,17ms ping to my host.
My standard fiber router is in bridge mode and then i have a Netgear RAX50 router behind that controls my network.
Then i have a network switch where me and my sons pc, alarm and my home assistant box is connected to and ofc the router that brings the network to that switch.
I have tried connect the cameras to a seperate switch, no change.
The cameras are locked to an ip adress with thier mac adress in my router so they will always have the same adresses
192.168.1.140 and 141 they are never been giving other adresses
and when they disconnect nothing else is having these adresses, so its not a conflict
when they are disconnected i cant go to and connect to them
The problem is, that they are losing network connection.
sometimes both of them within few seconds
sometimes only one of them.
Sometimes they come back right away
sometimes i have to replug network cable and then they come back right away (IS THAT NORMAL ?)
They are not contactable over network, but i can see router is connectet with light, so cable works.
They dont have ip any ip adress anymore and dont show up on a ip scan or in attached devices in router.
They simply loses the ipadress.
after a long fail search mail correspondence with reolink where they trying all the basic stuff, they came up with an offer, that i could get 2 new cameras.
i got 2 new cameras but newer models 2x 2x RLC-511WA. But they were not poe so i had to pull a power cord to them
i was happy and waited 8 days for them to return, finally got them, they were running fine for a couple of days, and then they went down AGAIN !!!
and keeps failing on network on and off. latest this morning 06.33 and after 2 hours they are still down.
I cant figure out what happends, the cams dont have a log function, so cant see anything in the camera.
The fun is, they working with wifi, but the signal is low where the cameras is, so the streams are laggy and ghosting on the recordings, pretty much useless, but they never disconnects..
Can someone help me ? a frustraded ip cam owner.
