EYEsurv ESDV-TRIBRID-4/8/16
The Tribrid is a perfect recorder if you have preexisting analog cameras but want to make the move to IP or HD-CVI Cameras without changing out your whole surveillance system. No need to replace every single analog camera to get a better resolution. With the Tribrid you can keep a few of the analog cameras and upgrade one or two at a time to IP or HD-CVI!
EYEsurv ESDV-TRIBRID-4 for $599.99
EYEsurv ESDV-TRIBRID-8 for $699.99
EYEsurv ESDV-TRIBRID-16 for $999.99
EYEsurv ESDV-TRIBRIDPRO-16 for $1199.99
- The most versatile and interoperable surveillance recorder on the market
- Tribrid capability - Works with IP cameras, Analog Cameras, and HD-CVI Cameras
- Any combination of cameras up to 4, 8, or 16 cameras.
- Records analog cameras at the highest encoded resolution possible - 960H at 30 FPS
- Records HD-CVI Cameras up to 1080p resolution at 30 FPS
- Records IP Cameras up to 1080p resolution at 30 FPS. Onvif Conformant
- Holds up to 4 hard drives (when DVD burner is removed), Holds 2 when DVD burner is installed.
- Remote viewing through any PC or Cell Phone in the world - Free Cell phone app and Free PC software included
- Completely customizable recording schedule options. Record on motion or record full time or set a customized schedule to record both regular and motion recording
- 4 channel audio recording (16 channel on ESDV-TRIBRIDPRO-16)
- Two HDMI Outputs - 1 Main, 1 Spot Out
